does anyone know of a program that will let you remove extras and subtitles and also have the main menu play before the movie does? I can have the main menu play first when i use full disc mode but then i cant cut out extras unless i reauthor, which messes up the main menu.
I have actually tried this, but the "problem" I found with CloneDVD is that it only allows you to backup onto one DVD-5 (DVD+/-R) disc.
So in my case, I had a huge movie on dual-layer (DVD-9) format, so when I opened it in CloneDVD, it was giving me a compression ratio of around 45% (way to low for my liking!).
CloneDVD would be better if there was a way to split the movie among two DVD+/-R discs, or a way to set start/stop points.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Create DVD with selectable data file within main menu, help?
By Distearth in forum Authoring (DVD)Replies: 1Last Post: 2nd Jan 2010, 17:45 -
DVD skips the menu and automatically plays the main movie!
By kreky in forum Authoring (DVD)Replies: 7Last Post: 17th May 2008, 07:14 -
DVD Flick...(Making main menu with TS?)
By RobAdam in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2007, 06:29
