hi all
can anyone help pleaz
i have an svcd file and i have converted to mpeg1
i am now using tmpgenc dvd author
but i try to load the file i get error message that the video resolution can not be used for dvd..does anyone know what resolution i should be converting the image to and the frames per second to enable me to burn this as an mpeg1 on to a dvd disc
many thanx
badger
ay badger.g
SVCD resolution is 480 x 576 / 480 x480 (PAL/NTSC.) Valid DVD resolutions (from this site) are:
PAL
Video:
Up to 9.8 Mbit/sec MPEG2 or up to 1.856 MBit/sec MPEG1 video
720 x 576 pixels MPEG2
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps (frames/second)
NTSC
Video:
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps (frames/second)
23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video) -
Well, you could make your life easier and use SVCD2DVD. Other than that, you need to change the size from 480 X 480 to VCD size of 352 X 240. Also change the audio from 44K to 48K. The spec bitrate for VCD is 1150. Framerate is 29.97 (All NTSC specs) There are guides to the left for more information.
Click on the Guides link (over there <-<-<-) and search SVCD to DVD under format conversion for instructions.
In one method you leave the video as-is and many SVCD capable players will play it, in another you re-encode. 1/2 DVD res is a good choice (352x480) if you go the encoding route.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 19:36 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
