okay.
maybe i've never fully understood this app.
if i have an svcd movie in 2 parts and i want to merge them into 1 movie on a dvdr with chapters every 5 minutes, is there a way to set that up in authoring, or is it mandatory that i have 2 tracks on the dvdr if i have it as 2 bin/cue sets without re-authoring with a separate program...
thanks in advance,
I'm just learning myself. I use TMPGEnc DVD Author. I just put both parts as a track (They play one after the other automatically. Two movies per DVD and two tracks per DVD). I believe you can chapter both parts of the track in TDA and make as many chapters as you want. Most SVCD's are in two parts. Only problem I have is a 5 second overlap between the two parts. I know I can trim it out, but does'nt bother me that much. I have a lot of SVCD's I want to convert.
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
Merging mkv Files
By kurian in forum Newbie / General discussionsReplies: 28Last Post: 2nd Jan 2011, 08:57 -
Merging different type files
By gabriel01 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2009, 11:58 -
Merging 2 files before Encoding
By niteghost in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2009, 04:13 -
Merging two .ASS files together
By kinghlg in forum SubtitleReplies: 1Last Post: 11th Mar 2009, 04:01
