hi,
wondering if someone out there in the wide blue yonder can help me.
im still learning how to copy movies and am learning each day.
ive recently done .oooooooooooooo... half a dozen movies with dvdshrink
and they play fine but they start to go go blotchy,pixelated,squares come thru em and may even pause then stop. this happens on different
movies at different stages, and yet others that ive done play fine.
any takers?
regards
me
Usually caused by poor quality media. Also, a low bit rate vs. a larger resolution. Check media first.
Hello. -
hi,
ive actually done bout 50 or more movies using the same dvd-r's,
only that these last half dozen have been coming out with faults,
even tho it says burn done successfully..... go figure.
regards
me -
So try raising your bitrate or reducing your frame size if you're so sure it's not the DVD.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
can these faults in a video be rectified
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2011, 23:00 -
Standard Def DVD Movies With Best Picture Quality?
By avkhatri in forum Off topicReplies: 2Last Post: 8th Jul 2009, 18:29 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
How do I identify faults in MPEG files? Authoring programs crash...
By semmel in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2008, 23:28 -
Tool to detect avi/divx's for faults
By tfamok in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2008, 14:08
