To the moderator
About one week ago I have sent a message
Inquiring about how to delete / erase e thread
Posted on the forum.
The answer I got was to consult the forum help file
Witch I did. The info I got was that there use to be a
delete function that is no more active .It stipulated
That in order to delete a thread was either through the
Moderator or the edit function (deleting the message at that thread.)
I have tried through the edit, first there is one (maybe two)
Thread that refuse to let me “edit” msg “this tread is close
, you cannot have access to it.
As for the other ones I tried to delete them through the edit
(go to edit ,delete title and message ) It does not seem to work
I delete everything and when going back to the thread posting
It is still there? ?
Could you help in that matter or should you delete al thread could
advise me I will wait until everything is O.K. to post an other thread
The threads are from “samui”
Thank you for your help and comprehension.
samui
1. please post in the correct area ...
2. your question was already answered a week ago ..
(you can not delete - nor is there any reason for you to do so)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
Question how to selectively delete most used web entries in Foxfire
By jimdagys in forum ComputerReplies: 4Last Post: 18th Jun 2009, 23:59 -
Question how to delete computer with minimum number of clicks
By jimdagys in forum ComputerReplies: 45Last Post: 18th Mar 2009, 10:15
