  1. is it possible with TMPGenc dvd author
    to add a small clip right before the main menu is shown ?
  2. Would think so, depending on what series of effects you are looking for...
    simply enter the clip first and then your movie.
    set the firstplay action to "play first track"
    You can experiment from there....
    Either use a rw disk or play back on computer to judge results - & to save on burned disks.
  3. well i got a small mpeg file with opening credits
    its about 1.20 minutes long
    so what i want is to see this first when i insert the dvd
    and when thats clip has played it will go to the main menu where i can select from the menu play movie , chapters etc...
    the set the firstplay action to "play first track"
    i cant seem to find anywhere in tmpgenc
    was just a big guess since i know tmpgenc isnt that advanced to do some bigger things with
    maybe there is a program which can add stuff to the finished source or something ?
  4. To find the option in TDA:
    1) Open the program ( TMPGEnc DVD Auithor)
    2) Select "Create menu" located at screen top
    3) Look to the upper r/h area of the presented screen where it says "Firstplay action".
    4) Click on the little downward pointing arrow just to the right of the hi-lited box
    5) Select prefrred option.
    For more information, consult TMPGEnc DVD Author's help file.
  5. ah there it is lol
    my fault completly looked over it
    thanks for pointing it out
    gonna have a try with that option
