I have some videos and I'm burning them as VCDs.
The problem is that the videos are fullscreen. Is there anyway to make it into a widescreen or maybe a slightly smaller size so that it's not fullscreen?
Thanks for all your help.
Change the aspect ratio from 4:3 to 16:9 when you encode it.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I can't select the aspect ratio. The aspect ration seems to be already set and unchangeable when i select VCD.
Currently, it reads "1.0950 - CCIR601 525 lines (NTSC)"
there's no 4:3 or 16:9?!?!? -
Which program are you using? If TMPGEnc, unlock the setting first so you can change it.
Setting button>Video Tab>Aspect Ratio
Hold mouse over the words "aspect ratio", select unlock, change setting.
Been a while since I used it but I believe that's the process."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
Widescreen shows up on the PC but as fullscreen on the TV?
By Moontrash in forum Authoring (DVD)Replies: 8Last Post: 17th May 2010, 17:26 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 14:54 -
Merge fullscreen and widescreen
By jin007 in forum Newbie / General discussionsReplies: 8Last Post: 25th Jul 2008, 08:06 -
Widescreen To Fullscreen
By OG24 in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2007, 15:51
