  1. Hi
    Made a couple of rips with tmpg, and decided to give cce a a try.
    Using w2k, frameserving with Virtualdub 1.4.7 > vfapi 1.03b > cce 2.50 . In Vdub proxy is OFF, as cce simply won't accept the files with proxy on. I can see everything when doing a frame search from within cce, but when encoding files are completely blank. Futhermore, when encoding no frames seems to be moving in the frameserver-count (but they of course show when doing a framesearch)
    Now 3 days are down the drain trying to get this right. could someone please try to tell me what exactly is going on........
    Thanx,
    CruizeMe
    <font size=-1>[ This Message was edited by: CruizeMe on 2001-10-22 00:02:29 ]</font>
  2. cce sp v2.5 will accept .vdr signpost files directly. run acompat.exe to tell win2k that virtualdub needs to run as winnt4 sp5. and it's not cce that's incompatible with aviproxy mode, the problem is with vfapi
    <font size=-1>[ This Message was edited by: stanwebber on 2001-10-22 03:15:42 ]</font>
  3. Thanx, that sure did the trick )
    I read about it somewhere else, but they stated it was only for athlons...? Guess they were wrong.
    Once again, thanx
    CruizeMe
