Results 1 to 10 of 10
  1. I have converted an XviD.Avi file to mpeg for SVCD. When I play it on my computer it works fine, but when I copy it to disc there is no sound.
    Anybody know what could be causing this?
    Apr 2002
    The State of Frustration
    Sound format?
    Hello.
  3. I used this guide to convert the file and saved the extracted audio file as a wav file.
    http://www.gkhull.pwp.blueyonder.co.uk/avitosvcdguide.htm
  4. Originally Posted by aikidokid
    Yes. Your sound is most likely AC3. Use Goldwave to extract the audio to PCM then encode with that file as your audio input.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
    Apr 2002
    Can you give any more details as the sound format other than it is a wave file?
    Hello.
  6. Use Goldwave to extract the audio to PCM
    What it PCM?
    I got the following from AVICodec before I converted it.
    Audio : 102 MB, 129 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
    After I converted it to mpeg
    Audio : 0.0 B, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    Looking at this the audio file shows 0, but it plays on my PC.
    Nov 2003
    Houston, TX
    i've heard somewhere that some dvd players don't support mpeg-1 layer 2 audio? if ur using tmpgenc for the conversion select "linear PCM" instead.
    hope this helps, josh
  8. Thanks,
    As this forums says, it's for newbies.
    Where will I find Linear PCM and what is PCM?
  9. Originally Posted by aikidokid
    Thanks,
    PCM is uncompressed audio.
    What grade are you aikidokid ?
  10. What grade are you aikidokid ?
    I am 4th Dan, practising Ki Aikido.
    Any you?
