Hi guys!
I have this avi movie that i like a lot. I like it so much that i'm willing to spend some time to manually make subtitles for it. The problem is that i don't know how.
Is there anybody in this superb forum who can tell me what software i'm going to need, and perhaps a little guide on the subject?
pretty pleeeeaaaase!!
umm, well for 1 a VERY FAST computer
Virtual PC with XP Pro
Sub Station Alpha
And a shitload of time
You will just want to load the avi's mp3 or wav track into it, and go through typing the subs. For a 30 min TV show, it will take about 10-12 hrs to sub completely. Then you need friends to look through your work, and check for spelling errors, and such.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
DVD Studio Pro 2 offers subtitle creation. Don't know how it works though...
Also, Textation X can be used to create subtitles.
I think a wise man once said "VPC solves nothing." I guess he was right.If it isn't broken, take it apart and find out why.
blog: deadsierra -
substation alpha is way easier to use. You just select that audio part, and it creates the timecode for it. Its very, very tedious work.
Q"Good Luck 007"
how do you make subtitles bigger?
By zinc in forum SubtitleReplies: 20Last Post: 29th Aug 2016, 01:47 -
How can I do these 2...remove subtitles and make my own hardsub
By Rippl in forum SubtitleReplies: 4Last Post: 14th Feb 2011, 08:51 -
How to make idx/sub subtitles
By GoldenDragon in forum SubtitleReplies: 5Last Post: 1st Sep 2010, 10:40 -
How to make subtitles HARD in DVD
By blue2 in forum Authoring (DVD)Replies: 4Last Post: 14th Mar 2009, 13:27 -
How do you make subtitles for .mp4?
By showmi in forum SubtitleReplies: 0Last Post: 7th Jul 2008, 12:55
