Hello!
I have the following problem: I am encoding my camcorder AVI files with TMPGENC into separate M2V and WAV files for quality purposes. When I try to join some of the M2V files with DVTools, though, I notice that there is a problem with the length of the file. The length of the joint M2V files don't add up to the length of the joint WAV files.
When I looked into it a bit further, I noticed that different programs show me different lengths for the same file: DVD Workshop shows a different (and the correct one, I believe) length than ZPlayer and PowerDVD.
Does anybody know a solution?
Please don't advise me, though, to join the avi files first and then convert it into the MPG elementary streams. For that, I don't have enough disk space.
Thanks!
