Finding Nemo disc 1 is a wide screen version with English only audio track.
Finding Nemo disc 2 is a full screen version that has French audio track.
Is it possible to extract only the French audio track from disc 2. Then
create a new DVD which is disc 1 added with the French audio track ?
How ?
Thanks.
You could use DVDDecrypter to extract the French track off disc 2, and use IFOEdit in Reauthor mode to add it to the movie of disc 1. There are guides for each process in the Guides section.
Thanks for your reply.
I've downloaded SmartRipper 2.41 and IFOEdit 0.96.
I used SmartRipper to extract the French audio track from disc 2.
I used SmartRipper to create the extra files for disc 1.
Then, I used IFOEdit in reauthoring mode to add the French audio track.
I burned the resulting disc using DVD Shrink 3.1 and it worked fine.
But, the only "annoying" thing is the English and French audio tracks
are both shown as Deustch in the DVD player. I've checked with DVD
Shrink and both audio tracks are shown as Deustch also.
Is there a cure for that small problem ?
I think the culprit is IFOEdit.
extract/edit/merge audio track
By skatenglide in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2012, 21:13 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
Need Help! Can't extract Audio track from MKV - Did I do something wrong?
By nametaken-7 in forum Video ConversionReplies: 5Last Post: 1st Oct 2010, 19:44 -
How to extract a song from a Karaoke disc?
By happybighead in forum DVD RippingReplies: 2Last Post: 6th Jan 2008, 07:09 -
ROXIO Music Disc Creator 9 --- track Lists / Shuffle
By Trollheart in forum AudioReplies: 2Last Post: 11th Dec 2007, 16:10
