Ok, I might just need a link to a guide, I have looked but cant find one.
I've got several episodes of video that I want on 1 DVD with a menu at the beginning of the disk to each of the episodes (can be quite basic) and also chapter intervals within each episode.
I've already encoded the Mpegs with tmpgenc plus and I'll be using Tmpgenc dvd author to create the dvd.
can anyone give me a starting point as to how to do this?
Results 1 to 23 of 23
DVDAuthorGUI can do it, it's freeware. Aren't there any guides for your authoring prog? There are a couple guides for DVDAuthorGUI if you look in Guides>How to category>How to author a basic DVD. For some reason you can't find them searching by tool within the guides. Maybe try the same search procedure for TMPGEnc DVD Author? Good Luck.
Pull! Bang! Darn! -
ok thanks, I think I've got a fair idea how to do it after searching through some other thread.
I'm guessing in tmpgenc dvd author I add each episode as a new track rather then just adding each file to the same track then there's some kind of template for creating a basic menu.
Is this right? -
Originally Posted by ashsharmaThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Is this right?
after you've selected where your audio and video files can be found, there's a button that says "edit clip" on the upper-left corner of the window. You can use that option to enter chapter points.
once you're done adding all your video clips and chapter points, the next step will allow you to customize the menus. -
Excellent, it worked a treat, I especially like the moving thumbnails of each episode and each chapter, though I'm not sure if these take up a lot of extra room on the disk?
...though I'm not sure if these take up a lot of extra room on the disk?
From reading the info on https://www.videohelp.com/dvd#struct (section titled "DVD File/Folder Structure"), it looks like you need to look how motion menus affect the size of "VTS_01_0.VOB"...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Ah, I'll check it later, I didn't really pay much attention to the sizes when I burned them using Nero, I don't remember any of these being to large though, maybe a few Mb.
The reason I asked it because I have another set of episodes that I hoped to fit onto a single dvd, however the total length is 245 mins, so I'm guessing these might not all fit onto 1 dvd, is this correct? -
I've seen this approach mentioned, though never tried it: You could have a try at what's called "1/2 D1" - 352 x 480/576 - as you can use much lower bitrates (not sure what values), and it's still a valid DVD spec so should still play on your stand-alone DVD player. Particularly if you're source is VHS tapes...
I'm not sure how much you can fit on a disc though... A quick look at the DVDRHelp Bitrate Calculator said that to get 2h45m onto a DVD, the rate would have to be around 3,400 kbps (for full D1). At 1/2 D1, I'm guessing if you use a rate of around 2,500kbps you should be OK in terms of size, and maybe (insert disclaimer here...) OK for quality.
I'm basing this on SVCD's being 480 x 480/576 and at 2,600kbps.
Have a search and read. I hope I've planted a seed of thought...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by daamon
Using the bitrate calculator is says the bitrate would need to be <2000, and I don't think it's possible to using a bitrate of less than 2000 on tmpgenc.
I think the only alternative I'll have is to cut parts of the episodes like the credit to try and gain 5 mins or maybe put it on 2 disks, unless you have any other ideas.
By the way, why can't you buy 9Gb recordable disks? would make life a lot easier! -
while in the menu options dialog box if you check and uncheck 'use motion menu' , the size of the dvd (in MB) in the colored bar at the bottom will change accordingly -
Sorry, it's 245mins not 2hr 45min.
But, the "1/2 D1" suggestion still stands - just means that you might have to do 2 DVD discs.
By the way, why can't you buy 9Gb recordable disks? would make life a lot easier!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I'm not sure if you are referring to TMPGEnc or TMPGEnc DVD Author.
Either way you can jack the bitrate way down. In TMPGEnc, just edit one of the standard templates. I've created several different new templates. Some at full resolution, some at half D1 and even a couple of DVD templates for converting VCD to dvd that have bitrates of 1250-1500 with 352 X 240 resolution. You have to be sure to leave the GOP settings unchanged if you want to us TDA though.
The quality isn't great, but that's the source.
A few things you can try to save space. When creating your dvd make sure you only create the main menu if you don't need to have chapter point menus. You'll still have the chapter points, just no menu pages for them.
You can also forgo motion menus....for a half dozen thumbnails that can be 100-200MB depending on thumbnail size. If you want motion menus you can reduce the loop time.
You can also create an oversized VIDEO_TS folder and then use DVD Shrink to reduce it. -
Originally Posted by briandugas
On the other hand, 3,4000kbs at 352x480 is not a crappy ration of bits/resolution. So, at 1/2 D1 you get more bits per frame, resulting in a better looking picture.
I have to say, that this is all hypothisis as I've never done it - I'm just going on what I know and what I've read.
As I hinted at earlier, the quality won't be up to SVCD, but will be nearer to that than VCD. And won't matter too much if the source is VHS (or similar quality).
@ ashsharma
If you give the "1/2 D1" a go at 2,200 kbps (don't forget to take the audio into account), please post back how it turned out...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
BTW what the exact size in MB you can fit on a dvd using overburn? -
1st...open TMPGEnc in standard form without the wizard. Then, on the bottom right hand corner click load and select the standard DVD template.
Next, save the template in another folder. You can create a folder of edited templates. This way, the supplied templates aren't changed.
Then click load again and load your newly saved template. Next click on settings and you're ready to edit the options. If an option (and most of them will be at this point) is unaccessible/greyed-out, simply right click on the line item and then you can 'unlock' the option and edit.
This way you can change resolution etc.
You can also now change the bitrate settings. For VBR for instance, you could set 0 as minimum, 1850 as maximum, 1500 as average. You can experiment with different settings, not only comparing various VBR template possibilities, but those of CBR and Constant Quality as well.
Don't even open the GOP Structure page...you won't need to change anything there. Just the Video page and the Audio page need some editing at this point if you want to reduce file size, and perhaps you'll be in the advanced page if you're applying filters.
While editing, you can even open a second copy of TMPGEnc so as to simply open the supplied DVD template, that way you can compare your edited version to make sure you haven't inadvertantly made some changes. You'll still be able to read most of the settings in the supplied template even if it is greyed-out. -
Thanks very much for the info, I'll give it a go.
Maybe I'm getting confused about the overburning but I'm sure I read somewhere on the forum that some software reduces the size a dvd can be by not reading to the absolute edge of the dvd, and this can be corrected by overburning. I might be completely wrong but I'm sure I've used an overburning function when burning dvds and vcds -
It seemed to work fine leaving the video bitrate at 2000 and reducing the audio bitrate a bit and it they just managed to fit onto a dvd.
Going back to the original subject, I've managed to create the menu fine, but how do get it to NOT include one of the tracks in the menu.
Um, maybe I should make it a bit clearer.
What I've done is encode the first 5 seconds of one of the episode to give an intro to the dvd. Then I've got the menu to play listing each of the episodes for selection, but it also lists the intro mpeg which I dont want. anyway to get rid of this.
also what settings do I use if I want to put chapters on each of the tracks but not include the chapters in the menu? I tried to unselect them all but then when I played the dvd I could navigate between the tracks but not play them!
any help would be greatly appreciated. -
For the chapters when you go into the menu settings just make sure it's set to "main menu ONLY" and not "main menu and track menu". Also make sure that the intro is set to firstplay option. You also might want to tell it to go back to main menu after it's done playing one of the tracks. I'm having trouble remembering where you set up the chapters in the program but I know its in one of the setup menu's...ah! When you are on the screen where you actually insert the video files and you can click on the settings of the individual files (not the track settings) and there is a tab in there for cutting and chapter selection. Just find the frame you want the new chapter to begin at..take note of the exact time..then go to the "add" button to the right where it shows the chapters.
Sorry if you already knew all that.
As far as keeping the intro from showing up in the main menu that is a toughie..i haven't dealt with that yet. Perhaps if you go back to the first screen and go to the track settings you can specify that it is an intro and should not be included..i'd be interested to see how that is done or if it can't be done due to the limitations of the program...
dlv
Scenarist basic blu-ray without menus?
By uridylylator in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Apr 2011, 03:46 -
Creating DVD Menus
By JARRE2000 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2009, 15:08 -
Creating menus
By Meriks in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2008, 15:11 -
need info on creating new menus on dvds
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 15:55 -
Subtitle woes..explanation of basic principles needed
By dADDo in forum Newbie / General discussionsReplies: 18Last Post: 9th Nov 2007, 01:55
