I am converting several divx file to put on 1 dvd-r disk but i am having problem. I read the bitrate and resolution information from the divx file from gspot and type it into TMPGEnc see screenshot but when i come to author it using TMPCEnc author i get an error about the resolution when i try using dvdpatcher i get GOP error could someone tell me wot i should do.
On TMPGEnc it is: MPEG-2 496x384 29.97fps CBR 935kbps, Layer-2 48000Hz 192kbps
that read from the divx file, do i need to encode with the standard dvd res because it takes alot longer. Or can i just patch the mpeg2 file?
Results 1 to 9 of 9
Good advice for a newbie.Originally Posted by Tommyknocker
Eventually, learn settings on your own. The TMPGEnc default templates suck.Want my help? Ask here! (not via PM!)
If i select that option only 1 file fit onto a dvd-r it encoded the file as standard dvd res and at 6000kbps when the files is only 935kbps by 496x384.
I have encoded to mpeg2 with the res 496x384 by 935kbps but dont know how to author it to copy to dvd-r. -
You can't. DVD files has to be of certain resolutions, most common 720x576/480 (PAL/NTSC).I have encoded to mpeg2 with the res 496x384 by 935kbps but dont know how to author it to copy to dvd-r.
Bitrates varies, but 6000 kbps is a good start point. I'd say absolutely minimum is 3000 kbps, max is around 9000 kbps.
The resolution/bit rate of your source material is totally beside the point.
/Mats -
I used to wizard to encode to: DVD for NTSC (North America and Japan) (MPEG-2 352x480 29.97fps CBR 2000kbps, Layer-2 48000Hz 384kbps)
There doesnt seem to be any loss of quality
I tried authoring a 10mb file and it seem to work this way. I just have to wait for my NEC dvd-rw 8x to arrive on thrusday and ill test if this work on my dvdplayer.
Cool - Yes, 352x480 is a vaid DVD res, and 2000 kbps is OK at that res too. What might be a problem is that not all players handle mp2 audio. AC3 and LPCM are the standard types of audio. LPCM takes an enormous amount of disc space, so AC3 is the way to go.
/Mats -
Ill try it on my ps2 but i have bought a new dvd player so i think it should work if not what is the best program to convert to AC3?
DVD (MPEG2) or DivX
By MI6 in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 13:51 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 11:52 -
divx to mpeg2 with winff = error
By tors10 in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 14:58 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 24th Aug 2007, 23:49 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57
