When I capture to Pc From Beta tapes using Adobe Premiere with a firewire port on a Sony Camera, I get out of sync with audio every 7 Minutes or so by 1 Frame. I dont have this issue at all capturing VHS Tapes. Any Suggestions
It's not the beta tape causing your synch problem, that's for sure.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Make sure you are capturing at the same framerate as the beta tape has been recorded to.Also bad frames in the beta can cause the audio to screw up,check for that.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Trying to play old Beta tapes
By razielle in forum RestorationReplies: 10Last Post: 6th May 2010, 09:54 -
creating mov files from mini dv and beta sp tapes
By bruceinva in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2009, 14:14 -
Questions on converting Beta tapes to DVD and quality
By rbatty11 in forum Video ConversionReplies: 7Last Post: 30th Apr 2008, 15:54 -
How to transform the audio tapes to CD?
By 1234567 in forum AudioReplies: 11Last Post: 4th Apr 2008, 11:01
