Hi!
after weeks of testing it seems that all my problems with subtitling my SVCD comes from the raw MPG, which I exported from NERO.
As it has worked once (!) and the only thing that changed since then is the order of codec (maybe also an additional codec) I wonder what codec would be the right?
My guess is that NERO uses a build-in codec, while WinSubMux uses something from the codecs installed. Thus MUXing seems to work but the player gets confused.
How can find out WHAT codec was used for the one sample that worked?
How can I determine what codec will be used by which software?
How can I get rid of ALL codecs installed and start from scratch (without reinstalling W98)?
Matthias
svcd is always mpeg2. this is not a free codec like codes from codec packs like nimo codec pack. mpeg2 is mostly supplied with dvd authoring software, like pinnacle studio etc. sometimes they name it different cos it's implemented differently (e.g. mpeg xs from edit studio), but it's still mpeg2.
Music was my first love, and it will be my last -
Well yes, I was aware of MPG2, but still there seem to be some differences in the codes.
Yes, there are diferences in the codecs.
About uninstalling all MPEG2 codecs, you can try uninstalling all DVD players, mpeg2 authoring etc, Nero, so on. Then do a egistry clean with some software such as RegSupreme or Norton SystemWorks. THen by using Zoom Player or similar kill all associations with MPEG video.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
Need A Codec
By TheVille in forum EditingReplies: 8Last Post: 14th Jan 2009, 09:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
which codec
By peterg60 in forum Video ConversionReplies: 6Last Post: 25th Jul 2007, 15:52
