How do you burn dvds with 2 dvdr's by using a image or dvd decrypter or copy of a movie? What software can I use?
I use Primo DVD to control 4 LF-D311s in one tower, and 4 A05s in another tower.
You should have each burner on a different IDE channel. For 2 burners, thats 3 channels, 1 for each burner, and 1 for the hard drive. If you don't have a MB with 4 channels, you can get an add in card for ~$30.
This is important, because, IDE doesn't allow for read/write at the same time across the same channel (Master/Slave). You may be able to burn at a slower speed, but most likely not at 4x 100% error proof.
Besides Primo DVD, Record Now Max, Nero, Disc Juglar all support multiple recorders. Nero (NeroNet) and Disc Juglar both support Network burning too. -
I'm using Record Now Max to burn to 2 drives simultaneously at 4X. They are on the same IDE (Master/Slave) and haven't had any problems.
I have also done this with Nero 6.
An NEC and a 105.
Andy -
Oh yeah?
I'll have to try that with RNM. I have an extra A05, and a Toshiba SD-R5111 already in a PC. I know Primo gave errors about different drives, then another warning about being on the same channel when I tried it before with these 2 drives. -
Originally Posted by drewson99
why do some dvds not allow elapsed time/chapter to display?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 10:27 -
burn 2 dvds at the same time.
By dymx in forum DVD & Blu-ray WritersReplies: 8Last Post: 12th Dec 2008, 16:58 -
Burn 3 DVDs at a time
By Dimava in forum DVD & Blu-ray WritersReplies: 42Last Post: 5th Aug 2008, 15:31 -
Any way to correct NTSC DVDs that are time compressed?
By PBear in forum DVD RippingReplies: 9Last Post: 2nd Aug 2008, 18:02 -
1st time on linux: looking to convert my DVDs to x264
By bgbop15 in forum LinuxReplies: 3Last Post: 19th Jul 2007, 13:56
