Overnet Says theres a firewall, I dont know what it is. I want to disable the firewall. Someone please help.
i have AOl and Nortons anti virus 2004
Results 1 to 9 of 9
In 'Control Panel'>Network Connections>Right click on your local area connection>Advanced. If you aren't using cable or DSL, you may have a problem with Norton.
Originally Posted by gooberguy
Turn off AOL?
i have the windows firewall disabled.
i dont know anything about NAV -
I think it may be AOL itself causing your problem.
Time to upgrade to a true ISP
Need Firewall for windows 8
By mysts in forum ComputerReplies: 8Last Post: 25th Nov 2012, 18:31 -
Which Firewall To Use In Windows 7?
By V Bot in forum ComputerReplies: 23Last Post: 30th May 2011, 22:34 -
best vista firewall
By Tbag in forum ComputerReplies: 51Last Post: 21st Oct 2008, 19:41 -
PC Tools Firewall Plus ??
By ofield1 in forum ComputerReplies: 8Last Post: 18th Mar 2008, 14:08 -
Comodo Firewall Pro - Free firewall
By bluemoss in forum ComputerReplies: 7Last Post: 10th Nov 2007, 09:44
