When I'm converting AVI to MPEG 2 in TMPGEnc ( for PAL DVD ), does it make much difference if I use PMC AUDIO or MP2 ? I am asking because I used MP2 and it won't play audio on one of my players. Is PMC more compatible?
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
MP2 audio was part of the PAL standard for a short time, but I believe they recently dropped it so its not always compatible with all hardware. PCM is definitely compatible with everything but it also hogs a huge amount of space. you'd be better off trying to encode it seperately to AC3 with FFMPEG GUI or a similar tool.
Originally Posted by tweedledee
2. Use TMPGEnc to encode the video stream only from your AVI (radar buttons in bottom right of window). This will give you a .m2v file - this is the video only component of an MPEG.
3. Combine the .m2v and the .ac3 during authoring. Note: If you're using TMPGEnc DVD Author whose version is before v1.5.20.62, it won't play the AC3 during the chapter selection, but it will allow it to "pass through" and should be heard OK on the burnt DVD disc.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
That's what I wanted to know. Many thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
No problem. Hope you get on OK.
Carpe diem.
Current US DVD players that can handle the PAL format...
By VDubMike in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Oct 2011, 23:00 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 00:34 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 10:46 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26
