I have been trying to burn a video file to cd using cdr-win ~ I loaded up the cue file and pressed start ~ it then came up with the following error
Error:Invalid CUE SHEET command at line 5
INDEX time is beyond the end-of-file
I have tried VCDImager to try to make a new cue file but that failed ~ and this is disc three of four ~ all the other cue files have written no problems.
Any help would be greatly appreciated![]()
Open the cue file with notepad and edit the first line so you take out the directory path eg.
FILE "C:\games\TEST.BIN" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
FILE "TEST.BIN" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
note that the change in the secind example now has no directory so the burning program doesnt look in the wrong area for the bin file,also if the name doesnt match the bin file then change it to do so.Also another thing you can do is use vcdeasy to extract the mpg from the bin file and then you can make another bin/cue file from the mpg. -
johnso,
many thanks indeed for all your help ~ will give it a try and let you know how i go one
johnso,
you would not believe it !! checked the cue file in notepad, and it showed the very top line ie name of file actually said .cue at the end.
I checked all the others and they said .bin at the top, so changed the name, saved it and hey presto, tried to write the cd and it worked.
If everything was so simply ~ thanks for the pointers
johnso,
tried to play my newest addition and it worked a treat ~ once again many thanks for all your help
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
