hi I am new to your program, I have paid & set up the program, but when I put 2 parts of a movie in it it will convert it all but, it put the svcd ad in the join saying please pay £10 to get the full version,this is the demo, can you please help, I realise it is easily sorted but , I need some help---many thanks Paul..................
Maybe a stupid question. But did you download the final version? After paying, you get a mail with a download link for the new version. Did you install this one?
Guido -
Go Here and get the latest version. Before installing remove the old version you have...
Then install the new one. Follow the instructions very carefully when it comes to installing the 2nd reg code...
I take it you have extracted & installed the .xml file to the correct dir as well.Not bothered by small problems...
Spend a night alone with a mosquito -
Also if you are using mpgs which have been processed by the demo then the advert is still in those sources.
From the website:
Please note that the demo will alter your source mpg files. It is advised that you use copies not the originals.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
thanks to all who replied, yes I have worked it out now & the program is working great --thanks Paul........................
missing subtitles in the middle of the movie
By steapien in forum SubtitleReplies: 5Last Post: 13th Dec 2009, 21:17 -
Adding an advert to the begining of a flim
By john59 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Dec 2009, 19:10 -
LG LDA 511 turns off in the middle of a movie!
By Wantonmaya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 16:56 -
How do I convert ISO files into a movie (newbie)?
By jkundi in forum Newbie / General discussionsReplies: 19Last Post: 28th Jul 2008, 08:27 -
How to add a scene in the middle of a movie
By L3PA in forum Authoring (DVD)Replies: 14Last Post: 16th Apr 2008, 04:47
