I am trying to run my satellite receiver through my computer and
capture some movies(I have BEV sat). I am using a AIW( but I am not sure of the model # because the computer was given to me) and hooking it up with s-video and audio directly to the sound card. I tried to follow the guides by lordsmurf but am unable to capture at anything higher than
640x240 same in virtualdub I can not set the resolution to 720x480 it only goes as high as ###x240 is this a concern?? I want to put the captured movies onto dvd also. other features in the guide also are differnent then my options the de-interlacing options are greyed out and set to progressive scan. Anyhow I am not having much sucess and am not very happy with the capture using mmc8.8 any help to point me in the right direction will be greatly apreciated, till then I will just keep reading.![]()
other info that may be of help:
the AIW pci card has a conexant fusion 878a chip and came with the long purple cord and box so you don't have to do the hook ups in back of the computer.
when I start the tv in the mmc I get this error
easy look can not be started because of out of date display drivers( is this just because my computer doesn't have a ati graphics card and has an nvidia card?????????
640x240
That's a limit of Virtual Dub when using WDM drivers in your system. The only way to capture more that 240 lines in VDub is to use VfW drivers.
Check out a program called Virtual VCR, it's available here. It allows capture resolutions like 720x480 using WDM drivers. I use it as a substitute to VDub. It has some special sync features as well, check it out.
Satellite PC Card Help Needed
By adamf154 in forum DVB / IPTVReplies: 23Last Post: 1st Sep 2010, 03:13 -
I just cancelled my satellite service.
By freebird73717 in forum Newbie / General discussionsReplies: 34Last Post: 25th Jul 2009, 11:38 -
Satellite TV on P.C software
By gomer in forum DVB / IPTVReplies: 3Last Post: 17th Jun 2009, 07:20 -
Old Satellite system
By MadDog_Smith in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2008, 14:51 -
How to capture video from satellite receiver's DVR two shows at a time?
By theinv in forum Capturing and VCRReplies: 7Last Post: 16th May 2007, 10:23
