i have a program that plays background music.
I LOVE THE SOUND IT PLAYS. It's like a hip techno beat, wha i wanna know is , is there a way to digitall record the sound, like maybe a feedback loop?
If i have broken the rules, i apologize.
Hi greg
Don't really know how to record music from a prog but I believe this topic has come up before and someone suggested a prog that can do that. The previous poster wanted sound from a game.
If you can't do that then if your sound card is duplex then you could also loop the speaker sound back to your line-in and record it it like an external sound.
btw... good question
i dont believe he broke any rules here. he is not talking about using this program, just that he likes the music it plays. anyway, i will help him instead of attacking him
theres a couple ways to capture this sound. you need an audio capture program, im sure there are plenty around here somewhere. the first way is to plug a mic into your mic port and put the mic up to the speakers to record the sound. i wouldnt recommend this though. i would recommend taking an audio cable, and hook it up from your speaker jack or output jack, into your mic jack or input jack. that way your computer will see the mic input, which is actually anything playing through the speakers. then capture away! -
In your favorite audio app, record using "What you hear" as your source as the sound plays.
Other possibilites you could try:
Total Recorder 4.4 from www.highcriteria.com (free trial d/l)
or, Audio Recorder Deluxe 2.2 from www.audio-recorder.net (free trial d/l).
Both will let you record directly from your audio path to HDD in MP3 or WAV format without any other hassles.Ethernet (n): something used to catch the etherbunny
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 08:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
