How you make two clips blend together by the end of the first clip and the start of the second one. So it looks smooth. Almost toning
Me personally I use AVISynth.
AVISource("clip1.avi").FadeOut(15)+AVISource("clip 2.avi").FadeIn(15)
etc, etc, etc.
I don't know how well AVISynth works with Ulead's software though."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
It doesn't. At least not on my system. Finfarin, try dropping your 2 clips into the storyboard mode, then click on the little effect place card between your clips. On the upper right corner, move the slider to "FX" and try the dissolve effect by dragging it to the effect place card between your clips. Hit play to preview. Try the other transitions too, you might find one you like more. Hope this helps.
Need help on using Corel VideoStudio X2
By natural4862 in forum Video ConversionReplies: 8Last Post: 12th Jun 2011, 05:13 -
VideoStudio PRO X3
By pepegot1 in forum EditingReplies: 0Last Post: 30th Jan 2010, 09:55 -
VideoStudio PRO X3
By pepegot1 in forum EditingReplies: 0Last Post: 27th Jan 2010, 17:20 -
Corel VideoStudio 12
By netmask56 in forum EditingReplies: 4Last Post: 20th Nov 2009, 00:25 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27
