  1. i have a ps2 with a mod chip fitted .
    i use disk swap trick action replay 2.
    is there any way to back up the boot disk.
    ive gone though loads off them i have about 3 cards now any help will do
    plz
  2. you could use the memory card exploit..
    basically, you program the MCE to whatever psx game you want to boot up with.. you can use cogswap, cdloader or swap magic elf.. once you've done that;
    insert psx cd w/ memory card containing exploit
    it will bring up either CS, CDL or SM, you put in your backkup and boot it.
    the psx disc will act as the boot disc, so if you screw it up, no big deal, go buy a cheapass used psx game for $1..
    you can get further information on how to do this @ www.ps2ownz.com
    as far as backing up the gameshark disc, you cant.. you could copy it, but it wouldnt boot up..
    you said you had a modchip, i'm guessing it a no solder modchip since you're having to use a swap trick..
    Mar 2003
    plz
    If you get scratches on your disks a disk doctor does wonders at making them work again
    http://www.epinions.com/content_59769523844
  4. Yeah, you can backup but I forgot what program to use. Never could do it myself but I know it can be done cause I have seen an ISO that works.
    Mar 2003
    You can use cloncd if your drive supports it and it takes a very long time but you cant use the copy to boot up an original game though these backups are mainly used for people that have modchips that want to use a gameshark
