hi, loking for trial version of dvdxcopyxpress..is there anywhere i can download it...im having alot of hassle with nero,..i get 95% into the burn , then i get a message saying burn failed...i,m using dvd shrink..and a pioneer 106...the disks that im using are dvd-rw ...ive tried it 6 times and i get the same result...any help would be appreciated...theted.
click on the hi-lited dvdxcopyxpress -> choose "download" from the next screen -> then scroll down on the 321 studios web page and click on "trial copy"....
that should get you close. -
Which version of nero are you using ??
Try a diffrent way of burning. Instead of burning straight to disk use nero to create a image file .iso is best and then burn that using nero. Takes a bit longer but may work.Not bothered by small problems...
Spend a night alone with a mosquito
