  1. Hi,
    I'm converting a clip using Procoder 1.5. The clip is xvid, 576x336 23fps and want to convert it to mpeg-2 ntsc. When I start the conversion the clip is upside down. What am i missing and what do I have to do to correct this. Thanks, Tony
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you will need to frame serve it with avsynth or v-dub and "flip image" ,you will also want to properly frame it or do an anamorphic image ..
    procoder has a pulldown setting in advanced menu - so you would encode at 23.98 and add pulldown .. (its in the extensive procoder manual - its HUGE!)
  3. Thanks for the reply. I'm a little unsure how to procede as i'm a newbie. I tried to load the file in Virtualdub and was unable, but could in Virtualdub Mod. I don't know where to go from there. As for the Procoder setting in the advanced menu. Would that solve my problem? Thanks again, Tony
