Hi all,
Having changed my burner to a Liteon LDW-811S I am finally able to play DVD+R on a very fussy car player using the bitsetting utility. The choice of media does seem to make some difference to the access time in the car.
This may sound like a stupid question but which manafacturer of media should I use? Is it a case of trial and error to find the best?
Any suggestions for good quality media?
Thanks!
Results 1 to 12 of 12
From my experience and many others I know, Ritek dye seems to come up on top...In particular the branded kind.
Ritek 4x overprints (orange top). They are about 61p at the moment. Fantastic discs. Try http://www.ukdvdr.co.uk.
There is no best bran per se as brands are ever chaning in quality and media id (see the media forum sticky)
Good brands at the moments include the following makers
Maxell Media id (mxl)
tdk media id (tdk)
ricoh media id
mitsubishi chemical company media id (mcc)
ritek GO3/4 media id
Taiyo yuden meida id -
not another one of these questions!
there is no "best" media. what works for one person might not work for another. you need to try some media, and find one that works good and fits your budget. having said that, i only use Ritek/Ridata discs, and i believe a lot of people on this site do to. i would suggest you try these, you can get them online and they are pretty cheap. -
Not necessarily, many agree ritke is good value, but quality wise theres currently better (even since the inconsistency of GO4 in recent months)
Originally Posted by elmotheteapot
all i can say is that out of a good 500 or so, I've never had a problem with a Ritek disc (several coasters - but all my own fault, trying things out) -
Best media is Taiyo Yuden DVD-R discs.
They can be bought in bulk from on-lines sites such as RIMA.COM or from retail stores such as BEST BUY on the FUJI label.
Be warned that the only FUJI DVD-R discs that are Taiyo Yuden brand are the packages that say MADE IN JAPAN (which tend to be the 10 packs and some have reported also seeing 5 packs). The bigger 25 and 50 spindle packs say MADE IN TAIWAN and are NOT Taiyo Yuden.
Everything else has produced some costers except for Princo. U have to burn a truckload of princo media to get 1 good copyGive a person a fish and you feed them for a day; teach that person to use the Internet and they won't bother you for weeks
Have you noticed that a slight tax increase costs you two hundred dollars and a substantial tax cut saves you thirty cents?
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 06:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
