I have a movie in 2 AVI segments. I want to merge them so make them DVDish.
The problem is the bit rates are different. I know this must be corrected before I can merge the two parts.
How do I correct the bit rates so they match up?
The first part is 1hr 15min. bitrate is: 1166 audio is: 128
The second part is:1hr 31min bit rate is: 924 audio is 128
Thanks alot.
The only way is to re-encode(which will reduce quality). Virtualdub can do that... load the avi, select and configure your compression, save avi.
"Art is making something out of nothing and selling it." - Frank Zappa -
I was once able to use VirtualDub "Direct Stream Copy" while specifying a new frame rate. I don't remember the specifics, but it can't hurt to try.
The outputted files merged no problem. -
Thanks guys. I'll try your suggestions, mess around a bit and see how I get on.
...as the governor once said...I'll be back
AVI to H264 equivalent bitrates
By supernano in forum Video ConversionReplies: 9Last Post: 27th Feb 2014, 02:21 -
flv to avi with best video bitrates
By projecttemp in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 07:41 -
Join two or more movies AVI and bitrates
By Jomapil in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2008, 16:20 -
Low bitrates with avi.NET
By DeathKing in forum Video ConversionReplies: 5Last Post: 11th Apr 2008, 03:28 -
Joining avi's - problem with differing bitrates
By Topher5000 in forum EditingReplies: 6Last Post: 12th Aug 2007, 20:54
