Hi, guys:
I have to multiplex m2v and ac3 with a 3rd-party multiplexer. I have a question with this regard - if I have captured video, then encoded it into M2V with VBR - can I multiplex it with AC3?
When I extract audio from the captured AVI file, the extraction program "does not know" that I am going to encode the video at VBR. And if the timecode does indeed move back and forth along the timeline during VBR encoding, here seems to be a potential problem when it comes to multiplexing.
Here is an excerpt from Cinema Craft Encoder guide which provoked this question:
<<If you want the amount of bits in each GOP to be the same, select CBR,and if you want the quality of each frame to be the same, select VBR. Note, however, that if you select VBR or 1-pass VBR, AUDIO MULTIPLEXING WILL NOT BE PERFORMED.>> (emphasis mine)
The question boils down essentially to this - can I safely encode an elementary video stream in VBR if I intend to multiplex it later?
Thx Walter
yes.
as long as you're not changing the framerate of the video, ie. changing the framerate from 25 to 29.97, it shouldn't affect your video/audio synch.
vbr makes 2 passes. first pass encodes the video with constant quality, and then the second pass will increase/decrease bitrate depending on what is going on in the movie. ie. increase in bitrate with action sequences, decrease bitrate if there is little to no action, etc. -
Thanks,
just to make sure. I was confused by that passage from CCE guide. I thought maybe the timecode delivery is not held at the same rate at VBR. Now I can safely encode at VBR and have shorter files.
walter
WMV with VBR Video to anything reasonable - audio aout of sync
By Syavi in forum Video ConversionReplies: 3Last Post: 11th Dec 2010, 13:00 -
Cause of A/V sync and how recognize when a video has VFR and audio has VBR?
By Stb1990 in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2010, 20:05 -
Need a video splitter that can handle all wmv formats and VBR audio codecs
By godfist314 in forum EditingReplies: 2Last Post: 5th Jul 2008, 15:15 -
how to do effectively obtain real time Video multiplexing
By vannigiova in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 11:05 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 15:51
