I need HELP, recently I downloaded a upgrade of a DVD back-up product. Every since I cannot get any program to burn a viewable back-up DVD. Prior to this download all was ok not perfect but OK. I have finally discovered my issue I think, somehow I have lost my ASPI, I have downloaded the adaptic update ASPI as well as the ASPI checker from Doom 9. The adeptic checker states that all updates are functioning properly and installed the Doom 9 checker gives me an error RED message saying the ASPI updates I have installed replaced a newer version. Now, I dont have a clue of how I lost the ASPI in the first place, but the restore option will not help me, I run Windows XP, today I am considering the purchase of another DVD Burning Program Nero 6, will this program help me correct the ASPI descrepancy ? If not what can I do ?
download Force ASPI from the tools section. use its dump feature to back up your current layer. then Kill the aspi layer entirely. then install the Force ASPI layer, which is basically a slightly modified version of Adaptec's 4.6 layer. the newer layer is still glitchy and they don't seem willing to fix it anytime soon.
oh and also of note, you can download Nero's ASPI Layer from the tools section too without having to pay for it.
programming??? nooooooooooooooo. I'm moving your topic. Try post in correct forum.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Burning problem with layer break?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Sep 2009, 13:08 -
HELP!! Dual Layer Problem with Titanium 10
By mnelson220 in forum MacReplies: 20Last Post: 21st Jan 2009, 00:50 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
