having problems all the sudden with "power calibration error" message when I try to burn dvd+r. worked fine for months then it just stopped one day. tried different media(tdk,hp)no luck. I used a couple of the tdk discs before with success. tried Pinnacle Instant Copy (the program I use all the time) and also tried Sonic MyDVD that came with the computerand both programs gave the same error message.after 3 hours on the phone with Dell still no dice. they want me to do a complete re-install to bring my system to out of box condition.but that is my last resort.it is a nec 4X burner running on a Dell 4600 2.8 ghz with 1 gig of ram. any help would be great.thanks
jlund@darkwing.uoregon.edu
i had this problem myself b4 and to cure it i had to reinstall the ide's. without knowing what ide drivers you need im not 100% but if you just delete them on xp anyway it should just reinstall them back with default drivers / settings after you reboot.
def worth trying b4 the factory disk neway. worked for me when my plextor was doing the same with pwr calibration errors.It appears that the CPU was operating so fast that it began to execute instructions before they arrived. This execution of future instructions created a small tear in space-time itself through which part of the cpu passed into a parallel universe -
Best to just search the forum for this one as there should be 50 topics or so.
tried re-installing the ide's,no luck.searched around a little bit in the forum,but nothing I found seemed to help in my certain situation.I hate to do a complete re-install of my system and find out it still doesnt work and that maybe ther is something wrong with the acull dvd writer.thanks for your help.
hmm, thats happening to me also, nec 1300a, burns ok at 2x but power calibration error when i try at 4x
VHS to PC Capture Calibration ...
By JasonCA in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 23:41 -
Imgburn - Power Calibration Error message
By concisa in forum Authoring (DVD)Replies: 6Last Post: 12th Nov 2009, 16:39 -
Power Calibration Area Error
By zork152 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Jul 2009, 18:27 -
Guide for Greyscale calibration
By Vrex in forum User guidesReplies: 0Last Post: 15th May 2008, 20:01 -
Nero's "Power Calibration Error" fix.
By AlecWest in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2007, 20:26
