I am looking to do the same thing with Ducktales episodes. Can anybody direct me to a good guide or help me out in any way?[/i]Yes it is possible to do, i got over 30 tom and jerry episodes on 1 dvd
ok first u need a little tool called TMPEGEnc to convert ur divx files so they are dvd complient.
theres a guide for it here http://www.polarhome.com/~afonic/tmpegenc.htm
after u convert your files use TMPEGEnc dvd author to create your, u put ur converted files in here and create menus once u finished doing that u have to shink the complieted dvd biffore u burn it to a disk, use dvd2one or dvd shrink to do this, then burn to a dvd and u can watch ur disc on any stand alone dvd player.
have a look at the guides to your left if u need any more help on doing this good luck
If you encode your videos as VCD's you should be able to fit around 20 22-minute episodes on one DVD. You just need to change the audio sampling frequency to 48,000hz. Once you have all your files made, import them into a DVD authoring program as the quote in your post suggests.
Deshaker settings
By fershad in forum Video ConversionReplies: 8Last Post: 30th Jan 2012, 20:03 -
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 19:55 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 09:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 15:20
