Can someone quickly step me through how to add audio to a menu and allow it to contiune when moving to another menu?
Thanks.
P.S. What format should the audio be in and what bitrate etc.?
TheGame7.
You might have better luck going directly to DVDlab's forum and asking. You'll have to register but that's the same as here.
http://www.mmbforums.com/modules.php?name=Forums&file=viewforum&f=9 -
You can't have one music that keeps playing when you switch menus - each menu has to have it's own music....Originally Posted by TheGame7
Check out this post:
https://www.videohelp.com/forum/viewtopic.php?p=778948#778948
Check the glossary on the left, and set it to a DVD standard (i.e. PCM, AC3, or MPEG audio if your region supports it)Originally Posted by TheGame7
<------------------------------------------"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Thanks for the replies
TheGame7 - "I am 'The Game' because I am that damn good!"
Need some Menu help from a DVD-lab PRO master
By jeanpave in forum Authoring (DVD)Replies: 13Last Post: 4th May 2010, 16:03 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 18:27 -
Audio Problem with VMG menu in DVD Lab Pro
By SCDVD in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2008, 23:15 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
Can you keep menu audio playing with Dvd-lab pro?
By jimjones2007 in forum Authoring (DVD)Replies: 7Last Post: 29th Aug 2007, 21:53
