hi all
i've been trying to get my hands on a top quality dvd to vcd converter,i want to make perfect copies of my dvds with out any blockyness i know this can be done because i recently i downloadid a movie in vcd format an it was perfect no blockyness an a nice sharp picture can anyone recommend a perfect dvd to vcd converter freeware or trialware
thanx
You can't realistically expect a low-resolution, low bitrate VCD to be "perfect" compared to a high-resolution, high bitrate DVD.
Having said that, I have backed up animated DVDs to VCD and they are virtually indistinguishable to my eye (not particularly fussy). A "live" DVD will always look worse - even to me.
Would I be right in guessing your downloaded VCD was animation?
Anyway, you can't go far wrong with the back-up guides on this site (to the left). TMPGEnc is free for MPEG1 (VCD), and on the highest quality setting is arguably as good as anything for VCD. -
well,yesterday I did my practice on how to put one whole movie in just 1 cdr.
I used SmartRipper,then DVD2AVI and TMPGEnc, the movie"IS GREAT" I play the cdr in my system which is in my room with a 13" tv and I won't ask for better quality,of course I can get a better quality but would take longer to convert the file to mpeg,you can choose VBR under TMPEGnc and will take longer and will get a better quality.
I use 1 small fraction of this guide,the part that teach how to fit one movie in 1 cdr,just from the TMPEGnc:
https://www.videohelp.com/forum/userguides/84759.php
and the movie fit just fine,and I didn't use over-burn.Rigo.F
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
ConvertXtoDVD Encoder Quality
By SCDVD in forum Video ConversionReplies: 17Last Post: 2nd Jun 2009, 13:23 -
High-quality two-pass MPEG-2 encoder alternative to Mencoder?
By fvisagie in forum Video ConversionReplies: 5Last Post: 30th Apr 2009, 02:36 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 11:42
