Before I demux, the video and audio was great and synced.
So I figure if I demux, TMPGenc would make a VCD video-only a little faster, then mux the audio back in.
Source file:
AIW capture 352x480 @ 3kbits / 44.1 layer-2 mpeg-1
1st try:
Demux mpeg and convert m1v to 352x240 @1.15kbits. Simple-mux m1v & mp2 = padding problems, bad mpeg.
2nd try:
Demux mpeg and convert m1v to 352x240 @ 1.15kbits and convert mp2 to wav. can't remux, so converted wav to mp3 using jukebox. Advanced-mux with m1v & mp3 = sound is choppy and video is jerky.
3rd try: Standard conversion to VCD: source = m1v and audio = mp3. Sound problems.
4th try: Standard conversion to VCD: source = m1v and audio = wav. Success, time consuming.
What spec should the mp3 be to mux??
Can I make a wav or mp3 into an ac3??
Can I convert my mpeg to SVCD since my bitrate is 3kbits??
Thanks in advance for any advice!!
Results 1 to 1 of 1
Video Re-Muxing Problem: How to Re-Mux to M2TS?
By WellBeSerious12 in forum Video ConversionReplies: 5Last Post: 15th Sep 2011, 02:31 -
AVI-Mux GUI problem
By toni-boy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Oct 2010, 12:37 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
ffmpeg mux problem with 2 pcm audiotracks
By thunder25 in forum Video ConversionReplies: 1Last Post: 15th Jun 2010, 08:41 -
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06
