Although it works fine with bought (pressed) DVDs, my Panasonic DMR E-50 has problems with automatic widescreen switching on home-made DVD-Rs.
I record on DVD-RAM, then copy this to my computer so I can make menus etc. I then amend the flags to be 16:9 format and copy back to a DVD-R. On my computer this disk then plays perfectly then adjusts the screen format as it should. However, on my TV I need to manually adjust the screen format for the program. But… it DOES automatically adjust to my home-made widescreen menus![]()
Any ideas please?
Hi there
you may want to pop over to
http://<br /> <a class="contentlink" href="http://www.thewholewideweb.com/forum/defau...ID=7</a><br />
They have quite a bit of information about widescreen recordings in there although I believe they are talking about the hs2 hard disk model dubbing to DVD-RAM/R.. might help though
Cheers
Ed -
Thanks Ed,
They don't seem as technical as this site but it's good to find a forum dedicated to Pannys. Thanks - much appreciated
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
problems importing widescreen video
By video_enthusiast07 in forum EditingReplies: 1Last Post: 10th May 2010, 02:18 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Problems Exporting Widescreen 16:9
By Funky Monk in forum EditingReplies: 3Last Post: 12th Sep 2009, 11:13 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
