Dear Friends
I have a problem and need your help to solve if you can.
I bought a Digital Satellite Card for my computer brand Vision Plus, and I capture films with it in MPEG2 format and it was great in quality but the problem is I tried to convert this copy from MPEG2 to DVD format “ Video-VTS” using program “ Neo Plus” to burn it after on a DVD Disk but I found out that after converting to Video-vts there is a picture without a sound, so I tried to use another program like “ Easy CD/DVD Creator V6.2 it works but I found out that after burning the film on a DVD disk the film are not complete the end titles are not there but there is a picture and sound I have installed all the codecs I found on the net so does any one faced the same problem or any body have a solution for it.
Looking for your help ASAP.
Best regards
Mike
Closed Thread
1) Stop for breath - use punctuation!
2) Check your original mpeg file for sound
3) How big is the original mpeg file - will it fit on a DVD?
4) Import the mpeg into TMPGEnc DVD author and see how you get on with the results.Regards,
Rob
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2009, 23:53 -
Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
By gallion311 in forum Video ConversionReplies: 2Last Post: 1st Dec 2008, 09:55 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 02:18 -
DvD convertying question
By rushhh in forum DVD RippingReplies: 2Last Post: 15th Jan 2008, 19:45 -
Pioneer DVD-RW DVR-110D using MAXELL disk problem!
By Lighters in forum DVD & Blu-ray WritersReplies: 7Last Post: 22nd May 2007, 07:29
