Hi all,
I recently purchased a TOSHIBA (bulk) DVD-R/RW which I found to be the chippest of its kind on the market. I also purchased a gudget called EZDVDmaker or something used to capture VCR-composite signal into DVD format via USB 2.0 port. The latter came bundled with ULead moviefactory 2 SE software. Although combining both hardware items I succeeded in producing my first DVD using Ulead's DIRECT-DISC option I can not get it to work witn any another option available on the moviefactory2 SE software. That is, if I try to create a project using the standard authoring process everything goes well until I get to the final "Finish" stage.
There, the software issues the message 'Please insert a DVD disc' and kicks me out, although there is a fresh DVD-R disk in the drive just like bebore.
Even deselecting the "record on disk" option and selecting either of the remaining options ('create DVD folders', or 'Create image file') doesn't work, this time issuing the message 'Failed to open disk'. (Which disk in that latter case really, the hard disk?).
Please, help me! Is this a limitation of the software as the version used is the 'SE' version? My operating system is Win2k and I have no other issues in general.
Thanks in advance,
manolis
Results 1 to 1 of 1
Autocrop fails
By w4tt4n4b3 in forum EditingReplies: 0Last Post: 11th Oct 2009, 15:31 -
AVI to DV fails after one.
By bmccall17 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2009, 12:49 -
mencoder fails
By scruss1 in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 23:48 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45
