  1. I mean that the user can choose A or B ..? is that possible?
    can anyone explain or give some guidness?
    Thanks.
  2. Depends what authoring program you're using. Theres a DVDLab guide in the guides section but it involves IfoEdit:
    https://www.videohelp.com/guides.php?guideid=392&howtoselect=3;24#392
  3. maa thanks but this is not what i ment...
    I ment a motion menu with an audio track that i can change it, not difrent audio language.
  4. I've seen DVDs with"menus" authored in to VTS PGCs instead of using the VTSM(anager) but no idea which authoríng program was used.
    In IfoEdit you get the line "Number of audio channels in VTSM" which does suggest there could be more....
  5. As far as I know, its not possible. Making an alternate menu on the other hand, is always feasible.
    All authoring software that I've seen only allows 1 audio track per menu.
