  1. Ive been encoding svcd at 720 x 576 , is this better or worse than 480 x 576?
  2. depends if you want to create DVD its fine. But if you want a SVCD compliant stream you should switch to 480x576.
    Plus your bitrate will be "spread" over less pixels so more available to give you a better picture
  3. just make sure that your dvd supports sxvcd if you use the 720x576 resolution
  4. As boas999 said the higher the resolution the higher the bitrate you need for the same quaility. Most people agree that 480x480/576 is more than good enough, as we can't reall see the difference. Now ???X240/288 makes a HUGE difference
    So for a given (often low compared to DVD) bitrate you should be better off at 480x576. However, this is all subjective so if it loooks good to you that's all that matters.
  5. 480x480 is more than good enough for me... I find that DVD's are seriously overkill. Using my stand-alone DVD player and TV, I can zoom in 2x and still not discern between DVD and SVCD...
