I am thinking of buying a LT XP Expert that I would use with my dishnetwork feed. This would mean that if I want to record or timeshift I would not use the tuner, but rather the S-Video input.
Does the hardware and software support this feature on the S-Video input, or does timeshifting only work on the tuner channels?
ADDED:
Maybe there is a better solution than what I am looking at.
Basically I have Dishnetwork at home and I wanted to be able to record shows. I was going to buy a Shuttle SK41G MiniPC and install a Leadtek Expert TV tuner card and use it's capture capability and software to do exactly that. BUT, maybe there is a better way of doing this instead of using a TV capture card, since I have no use for the actual tuner.
Any suggestions would be really nice. I am planning on networking the SK41G with my main PC and add two Hauppauge MediaMVP's later to make the recordings available all over the house.
Thanks,
Anosis
Results 1 to 1 of 1
Listen to me now and believe me later
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
VOB -> AVI (Timeshifting)??
By pmoscatt in forum Video ConversionReplies: 4Last Post: 5th Mar 2009, 23:11 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 14:44 -
Super fast video playback - framerate changing, timeshifting
By KOJV in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2007, 00:20
