Hi,
This pc uses WinXP.
The scanning software said it found to viruses and is not able to get rid of them. I also tried the text to fix it, however, that did not work either. I have no clue how the viruses got there. This pc was scanned for viruses and it found 2 on both .exe .dll explorers in the system32 folder.
How is the problem fixed without reformatting? Please and thank you.
Do I replace the explorers with one from the cd, maybe and if so how? Please and thank you. I did that once with win98 with the kernal32 file in dos mode, which worked great, however, I am not sure if it will work with explorer or win XP and I forgot and lost the rules to fix it in dos.
Is there a easier way for it to be fixed and if so how? Please and thank you.
Well more info would help alot. That aside try running the virus scanner from Safemode.
Hi,
when scanning in safe mode should I do this before (Start,Control panel, System, System Restore, then check the box thats says turn off system restore and when the message appears click ok? Please and thank you. -
hi,
It says something about melware if that is able to help more? Please and thank you.
How is it to be killed? Please and thank you. -
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/security/topics/virus/malware.asp
You said Explorer is detected? Read these also. This trojan does that.
http://www.cexx.org/dlder.htm
http://www.trendmicro.com/vinfo/virusencyclo/default5.asp?VName=TROJ_DLDER.A
Hope this helps.
Good luck.
Virus?
By pinetop in forum ComputerReplies: 5Last Post: 23rd May 2011, 15:11 -
Question about virus so terrible that Ghost restore did not kill the virus
By jimdagys in forum ComputerReplies: 24Last Post: 27th Apr 2010, 10:58 -
what is this virus
By romanstopme in forum ComputerReplies: 14Last Post: 12th Feb 2010, 17:50 -
VIRUS,VIRUS, Getting blocked accessing antivirus sites
By G)-(OST in forum ComputerReplies: 11Last Post: 10th Apr 2009, 02:40 -
virus or something else
By alintatoc in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:37
