The TV-Out on my video card doesent work, so i'm wondering, can I use a TV/Capture card in the same way as you would the TV-Out on a video card?
Only if it has TV-out.Originally Posted by bladestorm
You sure the TV out doesn't work? I can't use both at the same time on mine... -
It's dead, it has to be. I know I had it setup right both hardware and software wise. I troubleshot every possible option I had and still nothing.
I can only assume its defective since it doesent list the TV Chip type in display properties and TVtool even says on the config tab "TV-Chip: NONE" -
By the way, I have an old PCI MPEG2 Decoder card lying around that has a TV-Out. Do you think that would work? If so, how?
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 05:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 08:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 23:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 16:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 17:50
