Hello experts.
I have recently run into a small problem that I can't figure out. I was decoding an avi file in order to make a dvd. I stripped the audio from the avi then used TmpgEnc to make a m2v video file for my dvd.
Everything went well and in the end I had an audio file (ac3) and a video file (m2v)
I then used infoedit and muxed them all together and voila a dvd...
Perfect huh! No! Problem was that the audio file was damaged. Darn so that dvd became a coaster. Here is what I need....
I have since repaired the audio file its perfect now. What I'd like to do if possible is to get the video file from the dvd I made before. Is there a way I can strip the dvd file I made and take the video out to put it back to m2v format? I have the orginal avi but I no longer have the m2v file I made. What I hope to accomplish by all this is to save me the time of decoding the avi again. So that why I'd like to know if there was a way to get my video off the dvd.......
Your help would be appreciated...........
Archie
Think Before You Do It
You bet...
Tmpgenc, Mpeg Tools, Demultiplex, Browse, Files of Type *.*, browse to the Vob file, double click the video stream to multiplex, select save location. Done....
Since you're working with a created DVD it's not copy protected and TMPGEnc can work with the vob file straight off the dvd disk if you like.
If you wanted to use Tmpgenc Dvd Author you could select that VOB file as the video source and your repaired AC-3 audio stream as the audio source and go with it that way. There would be no need to demultiplex that vob. That program can handle vob files as input and a seperate audio stream no problem. This would save you some work. In Author just click 'add dvd video' instead of 'add file' to import the vob file(s) (main movie). After a click or two you will have the opportunity to select your repaired audio instead of the original stream. Very simple to do.
Good luck.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 22:58 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
