Hi, Folks:
Please offer any assistance that you can for the following error that occurred on my WinXP system during DVD backup operations. I suspect that it relates to my Pioneer DVR-106D DVD-RW drive. I have just successfully completed DVD Decrypter, DVD Shrink operations, and I had just reached 100% completion with the IMGTool operation. Here is that message, which appeared alonside a red circle with "X" in it:
I/O Error!
Device: [0:0:0](G)<--- my DVD-RW drive
CDB: 12 00 00 00 38 00
Interpretation: Inquiry
Reason: The specified network resource or device is no longer available.
Please note that my system is NOT NETWORKED. Hence, the error points to my DVD-RW drive or something associated with it.
Your prompt assistance will be GREATLY APPRECIATED.
Regards,
4ls
Try uninstalling it in device manager and rebooting your pc. Let windows re-detect and install the drive again.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Thanks, saca. . . .
Don't mean to appear ungrateful, but I tried what you suggested first or second. . . .Got any more ideas.
Alas, I suspect that this problem requires a "Device Manager Environs Guru." I believe that it relates to the configuration of the ATAPI Controllers(Primary and Secondary) and the Devices there.
Thanks for your response.
4ls -
I wish I had an answer for you. I used to get errors like that when I first got my burner. Before that I was using Adaptec's software to do all my CD burning with and was having all kinds of problems with my newly installed Sony DRU-500a drive so I just got rid of all their software and started using Nero. Haven't had any of them errors since though. Dunno if it was the Adaptec software or not, but it's sure a strange coincidence.
Ripbot - TrueHd stream related error
By Mitchmitchel in forum Blu-ray RippingReplies: 0Last Post: 11th Jun 2010, 17:07 -
Using Matroska splitter or related
By Blå_Mocka in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2009, 12:05 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
Subs and Size related.
By Ngnzakt in forum SubtitleReplies: 4Last Post: 16th Feb 2009, 22:31 -
You Tube related question
By bja5150 in forum ComputerReplies: 2Last Post: 24th Dec 2007, 10:39
