when i capture with virtual dub useing the huffyuv codec it comes up with ( avio output parameter incorect) after 30 minutes of capture any one got any ideas. also when i use virtual dub with picvideo mjpeg codec it works ok but when i play back the capture its has pic video on the screen, how do i get this off.
huffy codec is a lossless codec which means it don't compress so the avi will be big - in other words about 30 mins of video will be too big a file - the file size limit is 4 gigs for all OS but xp and 2000. So you've probably got an error that means the avi file is too big so it has dipped out. I seem to remember a similar error message when I've used this before. If you want to use the huffy you will have to enable multisegment capture which starts a new avi when it gets to a certain size (upto 2040 megs). See the guides on how to do this.
The pic video codecs give you banners on them cos it is not freeware - you will have to pay or use some other dodgy method of getting a cracked version. Or use div - x codec to compress and then convert it to mpegs - but the output quality will take a hit.
Regards
scattergun
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
