In the beginning. I had a clip in Three VOB files that needed some re-organizing and cutting of commercials. Also the audio was
flawed so I converted the AC3 files to WAV and fixed the clicks.
Now the re-authoring. I added dvd-video to TMPGENC dvd-author, but the sucker would not allow me to replace the audio's of all of those files with the WAV files.... now I make AC3 out of the files with BeSweet, audio that plays on my pc. I re-author with Tmpgenc DVD-Author, the result is two vobs, that I burn as a test...but get no audio on my standalone or pc.
Now I try to to see if I can use Wav audio by using Sonic DVd Producer and I open the two new Vobs in it...the program opens 3 VOBS! with 3 audios.... so basicly what I'm trying to achive is... I want the separate audio files for the THREE VOB FILES that are actually the TWO vob files on my HD so I can get the audio working for sure![]()
Or could I actually replace the audio of the vobs with WAV in TMPGENC DVD Author without getting an error ? I did try to DE-Multiplex the original vobs but .... I could not just get them to m2v + ac3 . Vobedit and Ifoedit do run in my pc, but they don't actually WORK.... (strange).
TMPGENC only processed two of the files to m2v but the third original vob would not de-multiplex.
Results 1 to 1 of 1
Having problems synching subtitles with VOBs
By somethingcd in forum SubtitleReplies: 0Last Post: 1st Feb 2012, 09:23 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 15:41 -
authored DVD freezing...but individual VOBs play fine
By Massa in forum Authoring (DVD)Replies: 8Last Post: 5th Jan 2009, 02:45 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12
