I've started using ritek dvd-rs with this purple die which claims to help the laser read the disk better....but I've noticed weird problems with my burner lately....get a lot of burning failed, or dvd is not blank (when it is).
And when I try to go through my computer to verify the disk is blank, it seems to run & run & run...but never opens the dvd... So I wondered if anyone had any opinions on these products with the ink & if that could be the root of the problem.
Tech support thinks its a software problem and I should uninstall, but I just don't want to go there. Any thoughts? Thanks.
The colour of the dye makes no difference whatsoever. The player / recorder does not "see" like you do. The dye colour issue is a myth, especially where DVD's are concerned.
Why are you trying to verify a disc as being blank ? The PC may take a long time trying to find data on a blank disc, that is not unusual. You can normally tell a burnt disc with the naked eye, so you shouldn't need to get the PC to do that. What I suspect happened in it failed to burn for a reason such as PCF failure, and the allotted space on the disc used for calibrating the writer was used up, rendering the disc useless.
More likely to be a problem is:
Bad batch of media / bad disc(s) within that batch
Incompatible media
Media not supported by firmware
... none of which is resolved by re-installing software.
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 03:20 -
Colored Bands Viewing AVI Files
By w6rlf in forum Video ConversionReplies: 11Last Post: 28th Sep 2009, 12:20 -
inkjet ink useage
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2009, 09:18 -
HP printer ink...for sale
By Krispy Kritter in forum ComputerReplies: 1Last Post: 23rd May 2008, 08:30 -
How to add a colored top and bottom for widescreen
By Jeff_NJ in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2007, 10:33
