Can I use VirtualDub for creating complex AviSynth scripts? I mean adding settings of filters, like VirtualDub LogoAway filter? Using the SCRIPT EDITOR function of VirtualDubMod I can set up range and trim, but that's all.
I can't remember where i saw it but there was a small application called "vcf2avs_gui.exe" that allowed a user to convert VirtualDub project files into AVISynth scripts. It used VirtualDub Plugins as AVISynth plugins.
Try a search for "vcf2avs_gui", there are a few different versions out there.
I know its not much but its all i have. -
Never had any success creating convaluted scripts with Vdubmod without it crashing.
Just bite the bullet ,use Notepad and do it manually - you'll learn more that way -
There seems to be a new download along side AVISynth.
Is this the official script editor?
http://sourceforge.net/projects/avisynth2/
VHS to DVD Restoration. Best AviSynth scripts?
By VideoFanatic in forum RestorationReplies: 47Last Post: 25th Oct 2011, 06:34 -
About using AviSynth scripts with MeGUI 0.3.5.0.
By Nagashi in forum DVD RippingReplies: 56Last Post: 15th Jul 2010, 10:15 -
I need some help on writing H.264 AVISynth scripts
By rocky12 in forum Newbie / General discussionsReplies: 46Last Post: 6th Dec 2008, 13:40 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23 -
Avisynth scripts and VDubMOD filters
By GangstaRap in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 11:39
